I would like to use the WIZ200WEB module to talk to 3X SPI D/A converters. My question is: can the WIZ200WEB’s SPI port be configured/ programmed to address any SPI device other than the on board temperature chip?
thank you,
Tim
thank you,
Tim
As far as I known, WIZ200Web’s SPI interface already assigned in temperature chip and have no other SPI interface for other SPI devices.
And WIZ200Web’s SPI interface is not connected to CONNECT header for interfacing external.
If you can implement the SPI protocol by GPIOs, You can use other SPI devices.
