Hi all,
i am using w5500 ethernet chip for one of my application. i can be able to set ip and establish connection with the given destination ip using tcp connection. But after establishing the connection i need to change my ip with different ip in same LAN and trying to make connection with same destination ip. But this time i am getting connection time out error while using connect function. Kindly suggest me the procedure for the same.
Thanks,
Hari Babu T D.
