Hi Joseph,
I would like to update my previous writing. I somehow reseted the system with pressing SW reset at start up, and it looks reinstalled a booting image. Now I get a output like this:
flash manufacture id: ef, device id 40 19
find flash: W25Q256FV
flash address mode: 4B
[WizFi630S] S/N: 22120T6FEEB8
[WizFi630S] MAC: 00:08:DC:6F:EE:B8
[WizFi630S] VER: 1.2.2
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM component: 1024 Mbits DDR, width 16
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
Date:Jun 2 2021 Time:16:27:22
icache: sets:512, ways:4, linesz:32 ,total:65536
dcache: sets:256, ways:4, linesz:32 ,total:32768
The CPU freq = 580 MHZ
estimate memory size =128 Mbytes
RESET MT7628 PHY!!!
Please choose the operation:
1: Load system code to SDRAM via TFTP.
2: Load system code then write to Flash via TFTP.
3: Boot system code via Flash (default).
4: Entr boot command line interface.
7: Load Boot Loader code then write to Flash via Serial.
9: Load Boot Loader code then write to Flash via TFTP
0
3: System Boot system code via Flash.
Booting image at bc050000 …
Image Name: MIPS OpenWrt Linux-5.4.188
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 2001102 Bytes = 1.9 MB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum … OK
Uncompressing Kernel Image … OK
No initrd
Transferring control to Linux (at address 80000000) …
Giving linux memsize in MB, 128
Starting kernel …
[ 0.000000] Linux version 5.4.188 (builder@buildhost) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16554-1d4dea6d4f)) #0 Sat Apr 16 12:59:34 2022
[ 0.000000] Board has DDR2
[ 0.000000] Analog PMU set to hw control
[ 0.000000] Digital PMU set to hw control
[ 0.000000] SoC Type: MediaTek MT7688 ver:1 eco:2
[ 0.000000] printk: bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
[ 0.000000] MIPS: machine is WIZnet WizFi630S
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32480
[ 0.000000] Kernel command line: console=ttyS1,115200 rootfstype=squashfs,jffs2
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Writing ErrCtl register=0004577b
[ 0.000000] Readback ErrCtl register=0004577b
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 122356K/131072K available (5094K kernel code, 206K rwdata, 636K rodata, 1220K init, 205K bss, 8716K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 256
[ 0.000000] intc: using register map from devicetree
[ 0.000000] random: get_random_bytes called from 0x805cfa28 with crng_init=0
[ 0.000000] CPU Clock: 580MHz
[ 0.000000] timer_probe: no matching timers found
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6590553264 ns
[ 0.000009] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
[ 0.007573] Calibrating delay loop… 385.02 BogoMIPS (lpj=770048)
[ 0.045459] pid_max: default: 32768 minimum: 301
[ 0.050134] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.057154] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.071172] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.080601] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.087263] pinctrl core: initialized pinctrl subsystem
[ 0.095326] NET: Registered protocol family 16
[ 0.132981] clocksource: Switched to clocksource MIPS
[ 0.138994] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.139432] NET: Registered protocol family 2
[ 0.149631] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.157577] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.165687] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.173061] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.179857] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.186146] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.192467] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.199458] NET: Registered protocol family 1
[ 0.203696] PCI: CLS 0 bytes, default 32
[ 0.212367] workingset: timestamp_bits=14 max_order=15 bucket_order=1
[ 0.227481] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.233123] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.258839] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.269587] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.275299] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.281026] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.286684] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.295757] printk: console [ttyS1] disabled
[ 0.299969] 10000c00.uartlite: ttyS1 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.308697] printk: console [ttyS1] enabled
[ 0.317111] printk: bootconsole [early0] disabled
[ 0.327339] 10000d00.uart1: ttyS0 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[ 0.337105] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.347634] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.373585] spi-nor spi0.0: enabling reset hack; may not recover from unexpected reboots
[ 0.381840] spi-nor spi0.0: w25q256 (32768 Kbytes)
[ 0.386758] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.393214] Creating 4 MTD partitions on “spi0.0”:
[ 0.398093] 0x000000000000-0x000000030000 : “u-boot”
[ 0.404338] 0x000000030000-0x000000040000 : “u-boot-env”
[ 0.410930] 0x000000040000-0x000000050000 : “factory”
[ 0.417379] 0x000000050000-0x000002000000 : “firmware”
[ 0.467570] rt3050-esw 10110000.esw: link changed 0x00
[ 0.476047] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[ 0.486798] NET: Registered protocol family 10
[ 0.496097] Segment Routing with IPv6
[ 0.500045] NET: Registered protocol family 17
[ 0.504655] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 0.517817] 8021q: 802.1Q VLAN Support v1.8
[ 0.524405] /dev/root: Can’t open blockdev
[ 0.528659] VFS: Cannot open root device “(null)” or unknown-block(0,0): error -6
[ 0.536268] Please append a correct “root=” boot option; here are the available partitions:
[ 0.544758] 1f00 192 mtdblock0
[ 0.544761] (driver?)
[ 0.551404] 1f01 64 mtdblock1
[ 0.551406] (driver?)
[ 0.558056] 1f02 64 mtdblock2
[ 0.558059] (driver?)
[ 0.564702] 1f03 32448 mtdblock3
[ 0.564705] (driver?)
[ 0.571355] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 0.579733] Rebooting in 1 seconds…
Can you help on? Thank you
