W6100 start
Hello I am new in w6100 and I must develop a project using atsamd21e17 MCU. The project will be a tcp client, tcp server and a udp server. Ip is IPv4 and must work with static and DHCP depending the settings. Please advice for a project I can use as a starting point and example
Hello.
WIZnet does not provide examples using the mcu. It would be good if you refer to the example below.
This is basic IPv4 DHCP
io6Library/Internet/DHCP4 at master · Wiznet/io6Library · GitHub
This is basic IPv6 DHCP
io6Library/Internet/DHCP6 at master · Wiznet/io6Library · GitHub
io6Library is the integrated library for dual TCP/IP statck contorller such as W6100.
You can run this code on your existing project.
Thank you
