Wizfi360 transparent mode with SoftAP and TCP-Server?
what I need is a module that can be configured as a SoftAP, with DHCP-Server and TCP-Server and automatically goes into transparent mode after a reset.
Here my Test Setting that don’t work:
AT+RESTORE
ready
AT+CWMODE_DEF=2
OK
AT+CIPAPMAC_CUR?
+CIPAPMAC_CUR:“02:08:dc:5d:63:62”
AT+GMR
AT version:1.1.1.9(Sep 5 2022 13:07:48)
compile time:Sep 5 2022 13:07:48
AT+CWSAP_DEF=“ASC-Modul_5d:63:62”,“”,11,0,1,0
OK
AT+CIPAP_DEF=“192.168.11.1”
OK
AT+CWDHCPS_DEF=1,120,“192.168.11.100”,“192.168.11.200”
OK
AT+CWDHCP_DEF=0,1
OK
AT+CIPMUX=1
OK
AT+CIPSERVERMAXCONN=1
OK
AT+CIPMODE=1
OK
AT+CIPSERVER=1,25000
OK
AT+SAVETRANSLINK=1,“192.168.11.1”,25000,“TCP”,25000,0
OK
But after reset module is still in command mode :frowning:
Have I do something wrong or is the module still not support than? When not supported do you plan it?
Regards,
Michael
Hi @Jackson0
WizFi360 is not yet supported to use transparent mode with SoftAP & TCP server.
I’m sorry I couldn’t give you the answer you wanted.
Are you planning to implement this feature in the near future?
Hi @Jackson0
Transparent mode with SoftAP & TCP server will be added, but there are no plans for when it will be added.
Please share your e-mail address.
If that function is added, we will send you the information by e-mail.
Hi Austin,
I have a current project where I need this function. If you could include this function in the short term I would order at least 500 modules. Otherwise I would have to go back to the RAK415 module which supports these functions for years.
My email: mktool(AT)gmx.net
Hi @Jackson0
There are no plans to add that funtion in the short term.
I’m sorry to tell you this.
