I’m having the following problem:
I have the W7500P and I’d like to flash the WIZ750SR firmware on it, such that it’s brought to the same state as the pre-programmed MCU.
I used the following settings in the “W7500 ISP Tool”:
The Firmware I’ve selected is WIZ750SRv133_incl_Boot.bin
The problem now is, however, that I cannot access the device with the “WIZnet S2E Configuration Tool V1.5.0”.
However the pre-programmed chip was working fine before I went to upload a new firmware.
Are the settings correct? Am I doing something wrong?
