Hi, When working with Arduino sketch, WizFi360EVB-Pico Bootloader is Corrupted and not detectable on Arduino IDE but can access the RPI-RP2 Drive when pressing BOOTSEL and plugging into the computer. I tried to use flash for the Micropython UF2 file and it works fine, but after can’t able to work with Arduino.
when burning the micropython bootloader, the device detected in Arduino but was not able to upload the sketch, and once by pressing the BOOTSEL button, it went to a non-responsive state.
Why do you want to use the damaged boot loader? First of all, it is necessary to use a normal boot loader
Wiznet provides an example of Arduino wizfi360-evb-pico.
Please refer to the github.
If what you want is a using micropython and micropython bootloader
You can download it from the website below. (micropython only ) MicroPython - Python for microcontrollers
we are going to release the Python code.
It will probably be released around November 1st (Korea time).
If you’re going to use a microwave, please wait and use it.
I’m glad it solved .
Please contact me if you need any other support.
And if your project is successful, post it on the maker site (https://maker.wiznet.io)
I hope it helps other maker
