I think the AT command manual states that in transparent mode, data is transmited every 20ms.
I would like to know if there is a way to configure this latency/timeout to just 1 or 2 ms,
or if it possible define some kind of line termination characters (like \r\n) to start transmiting immediately ?
Hello, this is Scarlet Team WIZnet.
Is the command you used “AT+CIPSEND”?
how about use the “AT+CIPSENDEX” command?
you can send it immediately when you enter “\0”.
refer Wizfi360 atcommand document
hello @FernandoPereira,
you mean, Is [UART - WiFi] what you need?
I’m sorry, but we can’t control the transmission time just by command or line termination characters.
Firmware needs to be modified to support configured latency time
I’m sorry I couldn’t help you.
I will try to apply it to the next update. ASAP
