If the firewall is on, data would not be sent.
Please check the firewall status and turn off it, and test again.
For the serial command mode, When using the Hercules tool you can use the CR/LF with $0d$0a like below.
To check the operation, change the view settings in the tool and check. And try sending it in the Send window at the bottom as follows.
The Baud rate seems to be set incorrectly in this part.
Could you try changing it to a different Baud rate setting?
And, if the debug message option is enabled, a message should be output through the serial port like below.
There seems to be a problem with serial communication.
I have checked documentation and settings and found Debug Mode was already on. Same can be seen in earlier shared screen shoots. I am sharing fresh screen shoot again.
Now I have pasted correct screenshot. FirmwareVersion is 4.06 at my end.
Earlier image was just to represent Debug Setting which has caused by confusion. Sorry for that.
Now I am aware of Debug Message Output setting, but I am not getting desired result.
Request you to provide response asap. If you have any India partner or team out here in India than please help me to connect with them.
We are completely stuck, and our project is not progressing. We are working on few repeat orders using this module and our design, development, enclosure is completely based on this module.
We have used earlier same modules and delivered.
Trying out any other modules at this stage, and 11th hour is challenge for us.
It is difficult to determine the problem…
You can try a factory reset.
The settings will be reset with factory default, so you can set the default options and test.
I think you have to also check the device connection.
WIZnet’s India branch is placed in Bengaluru.
You can contact with WIZnet India team. Please refer to the below link.
Check the module type again. It is one of the major causes of data corruption.
The TTL version should not have an RS-232 transceiver.
If the device has a transceiver, you have to use a USB to RS232 module, not a TTL module.
