These pins are already having internal pull-downs averaging at 85k. Thus the question is are these internal pull-downs enough and why some circuits have external pull-downs, and some not?
No idea. We must wait for WIZnet R&D to advise. If you need to make a design right now, just leave seats for those resistors, and will decide if to populate them or not later.
As Eugeny said, W5500 RSVD pin has internal pull-down(thanks Eugeny!).
The internal pull-down resistance value of 85K is too large and can be swayed by external noise. That’s why we used an external pull-down resistance of about 10K.
Reset pin is internal pull-up but as the same reason with RVSD pin, it can be use with external pull-up.
