Has anyone successfully been able to send/retrieve data from a USB CDC serial device on the W5500-EVB-Pico?
I have tried PICO-SDK or Arduino, using latest tinyUsb or Adafruit_tinyUsb library’s.
Tried, native USB, or the PIO-USB.
I finally got some devices recognized, but cannot send/retreive data.
If I run the default example device_info.ino, I get the descriptor when I connect the device:
Code from device_info.ino example:
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
MIT license, check LICENSE for more information
Copyright (c) 2019 Ha Thach for Adafruit Industries
All text above, and the splash screen below must be included in
any redistribution
// pio-usb is required for rp2040 host
#include "pio_usb.h"
#define HOST_PIN_DP 0 // Pin used as D+ for host, D- = D+ + 1
#include "Adafruit_TinyUSB.h"
#define LANGUAGE_ID 0x0409 // English
// USB Host object
Adafruit_USBH_Host USBHost;
// holding device descriptor
tusb_desc_device_t desc_device;
// the setup function runs once when you press reset or power the board
void setup() {
Serial1.begin(115200);
Serial.begin(115200);
//while ( !Serial ) delay(10); // wait for native usb
Serial.println("TinyUSB Dual Device Info Example");
void loop() {
// core1's setup
void setup1() {
Serial.println("Core1 setup to run TinyUSB host with pio-usb");
// Check for CPU frequency, must be multiple of 120Mhz for bit-banging USB
uint32_t cpu_hz = clock_get_hz(clk_sys);
if (cpu_hz != 120000000UL && cpu_hz != 240000000UL) {
while (!Serial) delay(10); // wait for native usb
Serial.printf("Error: CPU Clock = %u, PIO USB require CPU clock must be multiple of 120 Mhz\r\n", cpu_hz);
Serial.printf("Change your CPU Clock to either 120 or 240 Mhz in Menu->CPU Speed \r\n", cpu_hz);
while (1) delay(1);
pio_usb_configuration_t pio_cfg = PIO_USB_DEFAULT_CONFIG;
pio_cfg.pin_dp = HOST_PIN_DP;
USBHost.configure_pio_usb(1, &pio_cfg);
// run host stack on controller (rhport) 1
// Note: For rp2040 pico-pio-usb, calling USBHost.begin() on core1 will have most of the
// host bit-banging processing works done in core1 to free up core0 for other works
USBHost.begin(1);
// core1's loop
void loop1() {
USBHost.task();
// TinyUSB Host callbacks
// Invoked when device is mounted (configured)
void tuh_mount_cb(uint8_t daddr) {
Serial.printf("Device attached, address = %d\r\n", daddr);
if (tuh_cdc_mounted(daddr)) {
Serial.printf("Device is a cdc device!!", daddr);
} else {
Serial.printf("Device is NOT cdc DEVICE!!", daddr);
// Get Device Descriptor
tuh_descriptor_get_device(daddr, &desc_device, 18, print_device_descriptor, 0);
/// Invoked when device is unmounted (bus reset/unplugged)
void tuh_umount_cb(uint8_t daddr) {
Serial.printf("Device removed, address = %d\r\n", daddr);
void print_device_descriptor(tuh_xfer_t *xfer) {
if (XFER_RESULT_SUCCESS != xfer->result) {
Serial.printf("Failed to get device descriptor\r\n");
return;
uint8_t const daddr = xfer->daddr;
Serial.printf("Device %u: ID %04x:%04x\r\n", daddr, desc_device.idVendor, desc_device.idProduct);
Serial.printf("Device Descriptor:\r\n");
Serial.printf(" bLength %u\r\n", desc_device.bLength);
Serial.printf(" bDescriptorType %u\r\n", desc_device.bDescriptorType);
Serial.printf(" bcdUSB %04x\r\n", desc_device.bcdUSB);
Serial.printf(" bDeviceClass %u\r\n", desc_device.bDeviceClass);
Serial.printf(" bDeviceSubClass %u\r\n", desc_device.bDeviceSubClass);
Serial.printf(" bDeviceProtocol %u\r\n", desc_device.bDeviceProtocol);
Serial.printf(" bMaxPacketSize0 %u\r\n", desc_device.bMaxPacketSize0);
Serial.printf(" idVendor 0x%04x\r\n", desc_device.idVendor);
Serial.printf(" idProduct 0x%04x\r\n", desc_device.idProduct);
Serial.printf(" bcdDevice %04x\r\n", desc_device.bcdDevice);
// Get String descriptor using Sync API
uint16_t temp_buf[128];
Serial.printf(" iManufacturer %u ", desc_device.iManufacturer);
if (XFER_RESULT_SUCCESS == tuh_descriptor_get_manufacturer_string_sync(daddr, LANGUAGE_ID, temp_buf, sizeof(temp_buf))) {
print_utf16(temp_buf, TU_ARRAY_SIZE(temp_buf));
Serial.printf("\r\n");
Serial.printf(" iProduct %u ", desc_device.iProduct);
if (XFER_RESULT_SUCCESS == tuh_descriptor_get_product_string_sync(daddr, LANGUAGE_ID, temp_buf, sizeof(temp_buf))) {
Serial.printf(" iSerialNumber %u ", desc_device.iSerialNumber);
if (XFER_RESULT_SUCCESS == tuh_descriptor_get_serial_string_sync(daddr, LANGUAGE_ID, temp_buf, sizeof(temp_buf))) {
Serial.printf(" bNumConfigurations %u\r\n", desc_device.bNumConfigurations);
// String Descriptor Helper
static void _convert_utf16le_to_utf8(const uint16_t *utf16, size_t utf16_len, uint8_t *utf8, size_t utf8_len) {
// TODO: Check for runover.
(void)utf8_len;
// Get the UTF-16 length out of the data itself.
for (size_t i = 0; i < utf16_len; i++) {
uint16_t chr = utf16[i];
if (chr < 0x80) {
*utf8++ = chr & 0xff;
} else if (chr < 0x800) {
*utf8++ = (uint8_t)(0xC0 | (chr >> 6 & 0x1F));
*utf8++ = (uint8_t)(0x80 | (chr >> 0 & 0x3F));
} else {
// TODO: Verify surrogate.
*utf8++ = (uint8_t)(0xE0 | (chr >> 12 & 0x0F));
*utf8++ = (uint8_t)(0x80 | (chr >> 6 & 0x3F));
// TODO: Handle UTF-16 code points that take two entries.
// Count how many bytes a utf-16-le encoded string will take in utf-8.
static int _count_utf8_bytes(const uint16_t *buf, size_t len) {
size_t total_bytes = 0;
for (size_t i = 0; i < len; i++) {
uint16_t chr = buf[i];
if (chr < 0x80) {
total_bytes += 1;
total_bytes += 2;
} else {
total_bytes += 3;
return total_bytes;
static void print_utf16(uint16_t *temp_buf, size_t buf_len) {
size_t utf16_len = ((temp_buf[0] & 0xff) - 2) / sizeof(uint16_t);
size_t utf8_len = _count_utf8_bytes(temp_buf + 1, utf16_len);
_convert_utf16le_to_utf8(temp_buf + 1, utf16_len, (uint8_t *)temp_buf, sizeof(uint16_t) * buf_len);
((uint8_t *)temp_buf)[utf8_len] = '\0';
Serial.printf((char *)temp_buf);
I would expect for the serial_host_bridge.ino example to work, since I can see the USB communicates by giving the correct device description on attaching and detaching the device. But it doesn’t detect the device.
Code from serial_host_bridge example:
any redistribution
/* This example demonstrates use of Host Serial (CDC). SerialHost (declared below) is
* an object to manage an CDC peripheral connected to our USB Host connector. This example
* will forward all characters from Serial to SerialHost and vice versa.
* Note:
* - Device run on native usb controller (controller0)
* - Host run on bit-banging 2 GPIOs with the help of Pico-PIO-USB library (controller1)
* Requirements:
* - [Pico-PIO-USB](https://github.com/sekigon-gonnoc/Pico-PIO-USB) library
* - 2 consecutive GPIOs: D+ is defined by HOST_PIN_DP (gpio20), D- = D+ +1 (gpio21)
* - Provide VBus (5v) and GND for peripheral
* - CPU Speed must be either 120 or 240 Mhz. Selected via "Menu -> CPU Speed"
// TinyUSB lib
// Pin D+ for host, D- = D+ + 1
// USB Host object
// CDC Host object
Adafruit_USBH_CDC SerialHost;
// Setup and Loop on Core0
void setup() {
Serial.println("TinyUSB Host Serial Echo Example");
void loop()
uint8_t buf[64];
// Serial -> SerialHost
if (Serial.available()) {
size_t count = Serial.read(buf, sizeof(buf));
if ( SerialHost && SerialHost.connected() ) {
SerialHost.write(buf, count);
SerialHost.flush();
// SerialHost -> Serial
if ( SerialHost.connected() && SerialHost.available() ) {
size_t count = SerialHost.read(buf, sizeof(buf));
Serial.write(buf, count);
// Setup and Loop on Core1
void setup1() {
if ( cpu_hz != 120000000UL && cpu_hz != 240000000UL ) {
while ( !Serial ) {
while(1) {
delay(1);
#ifdef HOST_PIN_VBUS_EN
pinMode(HOST_PIN_VBUS_EN, OUTPUT);
// power off first
digitalWrite(HOST_PIN_VBUS_EN, 1-HOST_PIN_VBUS_EN_STATE);
delay(1);
// power on
digitalWrite(HOST_PIN_VBUS_EN, HOST_PIN_VBUS_EN_STATE);
delay(10);
#endif
USBHost.begin(1);
void loop1()
USBHost.task();
// periodically flush SerialHost if connected
SerialHost.flush();
// Invoked when a device with CDC interface is mounted
// idx is index of cdc interface in the internal pool.
void tuh_cdc_mount_cb(uint8_t idx) {
// bind SerialHost object to this interface index
SerialHost.begin(idx);
Serial.println("SerialHost is connected to a new CDC device");
// Invoked when a device with CDC interface is unmounted
void tuh_cdc_umount_cb(uint8_t idx) {
if (idx == SerialHost.getIndex()) {
// unbind SerialHost if this interface is unmounted
SerialHost.end();
Serial.println("SerialHost is disconnected");
When I try a device that has “bDeviceClass 2”.
It does get recognized by the serial_host_bridge.ino example, but I can’t send or receive data.
