I’m designing my first ethernet board and I’m not so experienced with hf applications.
I would like to show you my schematic and Layout, which is inspired by the Wiznet Ethernet shield.
3V3 and Gnd are not routed yet, but on the bottom layer there is plenty of space.
questions:
a) is my schematic ok?
b) what do you think about my layout / routing
c) where to place GND and where to place GNDA planes?
You do not use reset pin? Some components do not have part numbers. Power conductors of the same width as signal? There’s a document with guidelines, must be in the HW design guide archive on the W5100 product web page.
Thanks for your reply.
I thought, as I can shut down the power from my Controllerboard (with a RP2040, btw) I don’t need the reset… what do you think? I have only 3 GPIOs left…
What do you mean with “Power conductors of the same width as signal?”
I think that before you operate the chip you need to perform its hardware reset. This is a best practice.
The 3.3V conductors are too thin. Noise, current and EMI. They must be wider. I would place parts differently, C12 crossing is awful.
Crystal and ferrite beads at least are missing part numbers.
3.3v traces are to thin you say… I barely routed power traces, just some very short for the decoupling C - I wanted to route power mostly on bottom after I have my hf stuff.
to which traces do you refer exactly?
C12 crossing is awfull you said - yes!
But I’m stuck here, because R13 and R14 both connect to P5 and to RXN and RXP lines.
You can route power from another side of the board and connect stuff through vias. I would keep RX/TX lines free of vias if possible. I am sure you can achieve that.
that was the idea, because the plan is to let JLCPCB assemble that board.
It’s for an OpenSource project (OpenKNX), and we do not have a big budget.
Which components would you place on bottom side? R12/C11 and R13/14 and C14 ?
