I’ve got here a W3150A+ connected to a PHY on our own PCB. Well, SPI connection works fine, but if we perform a command (e.g. 0x10) to Sn_CR (Socket Command Register) it will not be executed. If we read the Sn_CR via SPI, the written command remains in Sn_CR. Sn_CR should be automatically cleared after a command was executed, that’
s what the datasheet says, or is another command necessary?
Can I assume, if the written command remains in Sn_CR, it was not executed? Or, was it executed but the automatic clearing mechanism didn’t work?
Can any (wrong) signal (too high, too low) on any Pin cause this problem?
Confusing:
We have also a NM7010B+, which is also useing a W3150A+ from WIZnet and for this module our code works finde. The Sn_CR is cleared immediately after writing.
Any suggestions?
Thanks a lot!
