I am working on evaluating WizFi360 module.
I have configured it as TCP client. I want to connect to https. So used command for SSL connection. It is getting connected. But while sending data, it is giving ‘ssl not supported’ in response. Please find below attached image for AT commands and its responses.
Hello @austin
Thanks for your reply.
I have tried using ‘AT+CIPSEND’ and it is working as expected for HTTP GET request.
Now, I am trying HTTP POST request.
I need to connect to graph.facebook.com with https. Then using whatsapp api, need to send message.
Following is the sequence
@austin
I checked using Postman utility. It is working as expected.
Compared data. Content-Length parameter found to be wrong.
Corrected it. Now I am able to hit whatsapp api using WizFi360 also.
Thanks for you support.
