Hello friends! I’m trying set the SSL connection with mbedTLS library with W5500 on STM32F767. I’m using your example and files from github (GitHub - Wiznet/ioLibrary_Driver: ioLibrary_Driver can be used for the application design of WIZnet TCP/IP chips as W5500, W5300, W5200, W5100 W5100S.). And i’m using Hardware RNG else. Socket open is sucess, connection to the server sucess next. While “handshake” i receive last messahe: “in_left: 0, nb_want: 5” and my programm don’t go next. I found out that programn stuck in recv() function in while() operator. recvsize always equal 0, getSn_RX_RSR(sn) function always return 0. What may be the problem? Why don’t work timeout break? Have is it here an implementation?
My DEBUG messages:
Start
Calling DHCP_run()…
=== W5500 NET CONF : DHCP ===
MAC: EA:11:22:33:44:EA
SIP: 192.168.21.6
GAR: 192.168.21.1
SUB: 255.255.255.0
DNS: 192.168.21.1
mbedtls_ctr_drbg_seed Ok!
Loading the CA root certificate
x509_crt_parse Ok!
. Setting up the SSL/TLS structure…
mbedtls_ssl_config_defaults Ok!
mbedtls_ssl_setup Ok!
mbedtls_ssl_set_hostname Ok!
Calling DNS_init()…
Resolving domain name “fallin.ru”…
Result: 188.124.41.188
Socket open ok! Connection to the fallin.ru ok! . Performing the SSL/TLS handshake…=> handshake
=> flush output
<= flush output
client state: MBEDTLS_SSL_HELLO_REQUEST
=> flush output
<= flush output
client state: MBEDTLS_SSL_CLIENT_HELLO
=> write client hello
=> write handshake message
=> write record
<= write record
<= write handshake message
<= write client hello
=> flush output
message length: 64, out_left: 64
ssl->f_send() returned 64 (-0xffffffc0)
<= flush output
client state: MBEDTLS_SSL_SERVER_HELLO
=> parse server hello
=> read record
=> fetch input
