AT+RESTORE=<type>, using an undocumented value for <type>
By mistake, the “AT+RESTORE=2” command was sent instead of the “AT+RESTORE=1” command.
AT+RESTORE=2
OK
76687460787878787878787878787878787878787878787878787878
  1. What happens after executing the “AT+RESTORE=2” command?
  2. What happens after executing the command “AT+RESTORE=type” if “type” contains an undocumented value?
AT+RESTORE=3
OK
value = 3(0x03)
ready
  1. Could this have led to the commands “AT+CWJAP_DEF…” and “AT+CWJAP_CUR…” now they always return the answer “ERROR”?
Hello @AndreyS
When recovery is not possible due to incorrect settings, try using it after re-writing the F/W.
Please refer to the document below for how to write F/W.
@austin thank you for the answer
I rewrote F/W before and after writing this post, but it didn’t solve the problem.
