Could you please let me know if my routing is good, or how can I improve it?
I have to use M12 connector for Ethernet connection, can’t find any reference layout for it. Two big extra holes are for plastic inserts for mechanical support.
Trace thickness: 10 mil
Distance between traces in the same pair: 8 mil
Length:
TX+: 855.669
TX-: 812.868
RX+: 431.944
RX-: 417.408
Hi there!
I saw the schematic and have a few questions.
L1 (33uH) is a power inductor. I recommend using a bead to isolate 3V3D and 3V3A. Is there a reason why you used a power inductor?
And case of M12 connector, you can design with any connector, but we can only guarantee optimal performance when using RJ45 jacks and cannot provide technical support otherwise.
I will change L1 to a ferrite bead, and connect LEDs to pin 25 and pin 27.
I am facing a difficulty in routing from the magnetic to W5500. The TX pair is crossing the RX pair. It is recommended not to use vias for differential pairs, so I run TX under the magnetic; but now the two TX traces in the TX pair cross and I cannot connect the other trace to R8. Please see attached screenshot.
