I’m having trouble updating the Sn_RX_RD register after a UDP packet has arrived. I’ve written a small monitor program that let’s me work with the registers so its easier to test.
The test is as follows: After the module is initialized I send a block of UDP messages from the Vixen Show software which embeds DMX512A light show information into Ethernet UDP packets. I then stop Vixen and look at the status of the WizNet550io. Below is the terminal session and comments describing the problem which is that I cannot update receive register. Even after writing a RECV command to the Command register. The data below shows that the WizNet has received at least 3 packets since the E1.31 Sequence number is correctly incremented.
So the data is being received by the WizNet550io and matches what I’ve seen with WireShark. The 8 byte UDP headers match the information. But I can’t change the value of the read pointer.
Suggestions?
Receiving ANSI E1.31 DMX512 packets sent by Vixen 3.0 and verified by WireShark.
WizNet550io parameters.
Gateway Address 192.168.0.1
Subnet Mask FF, FF, FF, 00
Source MAC Address 00, 08, DC, 1D, 4C, 4F
Source IP Address 192.168.0.125
Mode: 82, Cmd: 00
Interrupt: 04, Status: 22
Src Port: 15C0
Dest.Adr 01 00 5E 00 7F 00, Dest.IP 239.255.0.1, Dest Port: 15C0
Max Seg. Size 05C0
Sn_RX_RSR 079A, Sn_RX_RD 008B, Sn_RX_WR 0825
First 4 bytes describe source IP, the next 2 the Port # and the last 2 the
length of the UDP data which is the E1.31 DMX packet.
Sending IP #192.168.0.104, Sending Port # 50150
Length of ANSI E1.31 Packet is 0x83. Packet #0x65 at 0x102
008B: C0 A8 00 68 C3 E6 00 83 00 10 00 00 41 53 43 2D
009B: 45 31 2E 31 37 00 00 00 70 73 00 00 00 04 E4 43
00AB: 33 E9 36 F8 48 43 B6 98 02 59 F4 36 6D 5E 70 5D
00BB: 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00
00CB: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00DB: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00EB: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00FB: 00 00 00 00 64 00 00 65 00 00 01 70 10 02 A1 00
010B: 00 00 01 00 06 00 00 00 00 00 00
Length of ANSI E1.31 Packet is 0x83. Packet #0x66 at 0x18D
0116: C0 A8 00 68 C3 E6 00 83 00 10 00 00 41 53 43 2D
0126: 45 31 2E 31 37 00 00 00 70 73 00 00 00 04 E4 43
0136: 33 E9 36 F8 48 43 B6 98 02 59 F4 36 6D 5E 70 5D
0146: 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00
0156: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0166: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0176: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0186: 00 00 00 00 64 00 00 66 00 00 01 70 10 02 A1 00
0196: 00 00 01 00 06 00 00 00 00 00 00
Length of ANSI E1.31 Packet is 0x83. Packet #0x67 at 0x218
01A1: C0 A8 00 68 C3 E6 00 83 00 10 00 00 41 53 43 2D
01B1: 45 31 2E 31 37 00 00 00 70 73 00 00 00 04 E4 43
01C1: 33 E9 36 F8 48 43 B6 98 02 59 F4 36 6D 5E 70 5D
01D1: 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00
01E1: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01F1: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0201: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0211: 00 00 00 00 64 00 00 67 00 00 01 70 10 02 A1 00
0221: 00 00 01 00 06 00 00 00 00 00 00
Following the instructions at:
wizwiki.net/wiki/doku.php?id=pro … p_function
Reg:0x28 ← 0x0116
Reg:0x01 ← 0x40
Mode: 82, Cmd: 00
Src Port: 15C0
Max Seg. Size 05C0
Even writing Sn_RX_RSR+Sn_RX_RD to Sn_RX_RD and sending a RECV to the control register doesn’t change the read pointer.
Reg:0x28 ← 0x0825
Reg:0x01 ← 0x40
Mode: 82, Cmd: 00
Src Port: 15C0
Max Seg. Size 05C0
