Hi, the first time we powered our WIZ110SR, accidentally was with 12v 0.5A. The power supply was in 12v mode instead 5v (I know, rookie error ).
Now with 5v 0.5A the unit appears not to work. The RJ45 leds are off and the configuration tool canāt find the unit in our network.
As this units are not sold in Spain we ordered it to USA. We think we can replace the damaged componets with another from here instead ordering a new unit from USA.
Can anybody guide us to locate the damaged componets?
Iām sorry to hear that.
I donāt know whether voltage regulator was damaged or other parts like MCU or passive components were.
Anyway, try to change voltage regulator first.
In many cases, it makes good result.
Location āU5ā is LDO chip which drops 5V to 3.3V.
You can check whether it is damaged with a multimeter.
If its output voltage is not 3.3V, then change it with new one.
Thanks James.
I checked the LDO values. In the upper pin marks 1.14v and on the lower pins marks 1.89v (left), 1.14v (center) and 0v (right).
Iām going to look for a new LDO to make the change.
Iāll keep you informed.
[quote=ācolorinesā]
I checked the LDO values. In the upper pin marks 1.14v and on the lower pins marks 1.89v (left), 1.14v (center) and 0v (right).[/quote]
I have changed the LDO and the voltage values are still the sameā¦
Any idea?
There are two LDO. U5 and U7. U5 is 5V to 3.3V. U7 is 3.3V to 1.8V
LDO Part name is LM1117MPX-x.x (x.x is 3.3 or 1.8)
The upper-tab and center are output, Left-pin is GND. Right-pin is Input.
is right-pin 0V? I donāt understand. Please, remove U5 and U7 and then check input voltage if 5V from DC-adaptor jack
The 5V-net is only connected U5(LDO) from DC-adaptor jack. If 5V input is measured. You can assemble U5.
And then, Please check LDO voltage, again.
[quote=ācolorinesā]
Hi and sorry, the values I gave yesterday were wrong. The right values with the old LDO were 1,85v at the input, 0,39v at the out and 0v in GND. The values with the new LDO are the same.
It was inpossible to get the LM1117MPX-3.3. I use a LM1117T-3.3. It is a TO-220 type instead SOT-223 but itĀ“s equivalent. As the TO has 3 pins and a tab I made a bridge from the TOās tab to the contact were the SOT tab was solded.
Today I unsolded the C19 capacitor and the new LDO. The values measured at the contact board without LDO and capacitor are:
U5 LDO: 5v at the input, 0,39v at the out and 0v GND.
C19 Capacitor: 5v upper pin, 0v lower pin.
I solded the new LDO again and the values are:
U5 LDO: 1,85v IN, 0,75v OUT and 0v GND.
C19 Capacitor: 1,85v upper pin, 0v lower pin.
U7 LDO: 0,74v IN, O,65v OUT and 0v GND
I think there are something that makes the voltage supplied to the LDO be lower than usual.
