WIZ750SR Mechanical Dimension and PCB footprint
I’m trying to build the PCB footprint of WIZ750SR module but the mechanical information present on the WIZ750SR datasheet is incomplete
In particular:
  • what is the Y distance of the center of pin 1 of J2 and J4 connectors from the edge of the board ?
  • what is the X distance of the center of pin 1 of J1 connector from the edge of the board ?
  • is it available a PCB footprint ?
Hello. I’m sorry for the delay in answering.
I don’t know what you mean by whether footprints are available.
All materials are located in the link below.
If you can’t see the data with Altium, should I send the data with DXF? Or should I give it to Gerber?
Thanks
