I want to implement SPI with DMA for the W5500 chip using HAL in my existing project (which is written based on HAL). I found an example given in SPL. Likewise, I wasted lots of energy finding examples in HAL but failed. At last, I try to migrate SPL into HAL. But it is not working anymore.
Please help me to migrate SPL to HAL.
NB: without DMA it is working very fine.
MCU: STM32F401RC
Code:
My Implementation-
// this function is using for bothe read & write
void W5500_readBurstDma(uint8_t buff, uint16_t len)
/ SPI1 DMA Init /
/ SPI1_RX Init /
hdma_spi1_rx.Instance = DMA2_Stream0;
hdma_spi1_rx.Init.Channel = DMA_CHANNEL_3;
hdma_spi1_rx.Init.Direction = DMA_PERIPH_TO_MEMORY;
hdma_spi1_rx.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_spi1_rx.Init.MemInc = DMA_MINC_ENABLE;
hdma_spi1_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
hdma_spi1_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
hdma_spi1_rx.Init.Mode = DMA_NORMAL;
hdma_spi1_rx.Init.Priority = DMA_PRIORITY_HIGH;
hdma_spi1_rx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
if (HAL_DMA_Init(&hdma_spi1_rx) != HAL_OK)
Error_Handler();
__HAL_LINKDMA(hspi,hdmarx,hdma_spi1_rx);
/ SPI1_TX Init */
hdma_spi1_tx.Instance = DMA2_Stream3;
hdma_spi1_tx.Init.Channel = DMA_CHANNEL_3;
hdma_spi1_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
hdma_spi1_tx.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_spi1_tx.Init.MemInc = DMA_MINC_ENABLE;
hdma_spi1_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
hdma_spi1_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
hdma_spi1_tx.Init.Mode = DMA_NORMAL;
hdma_spi1_tx.Init.Priority = DMA_PRIORITY_HIGH;
hdma_spi1_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
if (HAL_DMA_Init(&hdma_spi1_tx) != HAL_OK)
Error_Handler();
__HAL_LINKDMA(hspi,hdmatx,hdma_spi1_tx);
W5500_select();
HAL_SPI_DMAResume(&hspi1);
__HAL_SPI_ENABLE(&hspi1);
HAL_DMA_Start(&hdma_spi1_tx, (uint32_t )buff, ( uint32_t )&hspi1.Instance->DR, len);
HAL_DMA_Start(&hdma_spi1_rx, ( uint32_t )&hspi1.Instance->DR,(uint32_t )buff, len);
W5500_deselect();
HAL_DMA_Abort(&hdma_spi1_tx);
HAL_DMA_Abort(&hdma_spi1_rx);
HAL_SPI_DMAPause(&hspi1);
__HAL_SPI_DISABLE(&hspi1);
SPL Example:
Visit the link:
- Implementing full duplex communication via SPI DMA on STM32F2xx or STM32F4xx
- w5100s_an_dma_v100e.pdf
SPI & DMA Configuration:
Pin Connection:
SRM32 - W5500
PA5 - SCK
PA6 - MISO
PA7 - MOSI
PC4 - CS
PB10 - IRQ
Thanks in advance
