Is it possible to set the different Phy configuration option (10 / 100 auto…full / half duplex) by software? If possible what are the pin configuration setup in hardware ? will the software registers will override or will the hardware setup override the configuration?
Thanks!
As I know, Internal PHY maybe configured by software register as PHYCFGR.
For more detail, refer to the datasheet.
Oks I found in datasheet that I must use the OPMD bit
[quote]Configure PHY Operation Mode
1: Configure with OPMDC[2:0] in PHYCFGR
0: Configure with the H/W PINs(PMODE[2:0])[/quote]
