I’m having a little problem.
I want to implement the InverseARP (not RARP) protocol using the W5100 chip.
So I’ve defined the socket 0 as:
IINCHIP_WRITE(Sn_MR(0),Sn_MR_IPRAW);
IINCHIP_WRITE(Sn_PROTO(0),IPPROTO_ICMP);
IINCHIP_WRITE(Sn_CR(0),Sn_CR_OPEN);
/* +20071122[chungs]:wait to process the command… */
while(IINCHIP_READ(Sn_CR(0)));
All work, but at this point I want to read the opcode and if the opcode is != from 8 (InARP) I wold like that the chip proceed the message handling by self without use my code.
How is possible to reput the messagege that I pick up from the chip in my buffer and the reput in the chip and force the automatic message elaboration?
Regards
Giuseppe
