WiFi Direct error
The WiFi direct method appears simple, but I can’t turn on it.
I get an error message.
I use the latest firmware with official EVB.
What is the problem?
WizFi250 Version 1.0.1.8 (WIZnet Co.Ltd)
AT+WP2P_START
[ERROR]
Szilard
Hello Ceelard
It looks like that there is no problem as below.
[code]WizFi250 Version 1.0.1.8 (WIZnet Co.Ltd)
AT+WP2P_START
STA MAC: FE:4D:D4:FF:97:FC
[OK]
Found P2P device: SHV-E250S
Sending Identity
Sending Identity
Sending nonce
Sending hashes
Sending WSC Done
[Link-Up Event]
IP Addr : 192.168.49.245
Gateway : 192.168.49.1[/code]
Please, try it again after factory reset.
Thanks a lot!
The factory reset solved the problem!
