Hi, striving to get the w5500 working on Particle Electron using NCD_Ethernet_Overlay.h/.cpp;
The lib supports Particle and the code seems to jive …
So I dove into SPI bus after verifying the obvious (pinMode / SS assignment, setSS(), resetSS() in EthernetClient.cpp, etc.), and here’s an example trace I got;
Are these Voltage swings unstable or should we expect a little slew / bounce?
EDIT - should now be full cycle.
And then is this about right for a SPI exchange?
Coz I’m getting nothing out of the RJ45 (Wireshark) despite verifying a PC can connect to the TCP server (@ 192.168.0.39), unlike this post which seemed to at least get something.
name type start_time duration mosi miso
CAN can_error 3.07339159 1.00E-05
SPI enable 3.07345541 4.00E-09
SPI result 3.07345682 1.00E-06 0x00 0x00
SPI result 3.07345922 1.00E-06 0x00 0xFA
SPI result 3.07346158 1.00E-06 0x00 0xFA
SPI result 3.07346395 1.00E-06 0x00 0x05
SPI disable 3.07346668 4.00E-09
SPI enable 3.07349923 4.00E-09
SPI result 3.07350062 1.00E-06 0x00 0x00
SPI result 3.07350302 1.00E-06 0x00 0xFA
SPI result 3.07350538 1.00E-06 0x04 0xFA
SPI result 3.07350775 1.00E-06 0x85 0x05
SPI disable 3.07351047 4.00E-09
SPI enable 3.07354303 4.00E-09
SPI result 3.07354441 1.00E-06 0x00 0x00
SPI result 3.07354681 1.00E-06 0x1E 0xFA
SPI result 3.07354918 1.00E-06 0x0C 0xFA
SPI result 3.07355155 1.00E-06 0x02 0x05
SPI disable 3.07355426 4.00E-09
SPI enable 3.07358683 4.00E-09
SPI result 3.07358821 1.00E-06 0x00 0x00
SPI result 3.07359061 1.00E-06 0x1F 0xFA
SPI result 3.07359298 1.00E-06 0x0C 0xFA
SPI result 3.07359534 1.00E-06 0x02 0x05
SPI disable 3.07359806 4.00E-09
SPI enable 3.07363069 4.00E-09
SPI result 3.07363208 1.00E-06 0x00 0x00
SPI result 3.07363448 1.00E-06 0x1E 0xFA
SPI result 3.07364028 1.00E-06 0x2C 0xFA
SPI result 3.07364274 1.00E-06 0x02 0x05
SPI disable 3.07364546 4.00E-09
SPI enable 3.07367809 4.00E-09
SPI result 3.07367947 1.00E-06 0x00 0x00
SPI result 3.07368187 1.00E-06 0x1F 0xFA
SPI result 3.07368424 1.00E-06 0x2C 0xFA
SPI result 3.0736866 1.00E-06 0x02 0x05
SPI disable 3.07368932 4.00E-09
SPI enable 3.07372195 4.00E-09
SPI result 3.07372334 1.00E-06 0x00 0x00
SPI result 3.07372574 1.00E-06 0x1E 0xFA
SPI result 3.0737281 1.00E-06 0x4C 0xFA
SPI result 3.07373047 1.00E-06 0x02 0x05
SPI disable 3.07373318 4.00E-09
SPI enable 3.07376575 4.00E-09
SPI result 3.07376713 1.00E-06 0x00 0x00
SPI result 3.07376953 1.00E-06 0x1F 0xFA
SPI result 3.0737719 1.00E-06 0x4C 0xFA
SPI result 3.07377427 1.00E-06 0x02 0x05
SPI disable 3.07377698 4.00E-09
SPI enable 3.07380961 4.00E-09
SPI result 3.073811 1.00E-06 0x00 0x00
SPI result 3.0738134 1.00E-06 0x1E 0xFA
SPI result 3.07381576 1.00E-06 0x6C 0xFA
SPI result 3.07381813 1.00E-06 0x02 0x05
SPI disable 3.07382085 4.00E-09
SPI enable 3.07385341 4.00E-09
SPI result 3.07385479 1.00E-06 0x00 0x00
SPI result 3.07385719 1.00E-06 0x1F 0xFA
SPI result 3.07385956 1.00E-06 0x6C 0xFA
SPI result 3.07386193 1.00E-06 0x02 0x05
SPI disable 3.07386464 4.00E-09
SPI enable 3.07389728 4.00E-09
SPI result 3.07389866 1.00E-06 0x00 0x00
SPI result 3.07390106 1.00E-06 0x1E 0xFA
SPI result 3.07390342 1.00E-06 0x8C 0xFA
SPI result 3.07390579 1.00E-06 0x02 0x05
SPI disable 3.0739085 4.00E-09
SPI enable 3.07394107 4.00E-09
SPI result 3.07394246 1.00E-06 0x00 0x00
SPI result 3.07394485 1.00E-06 0x1F 0xFA
SPI result 3.07394722 1.00E-06 0x8C 0xFA
SPI result 3.07394958 1.00E-06 0x02 0x05
SPI disable 3.0739523 4.00E-09
SPI enable 3.07398494 4.00E-09
SPI result 3.07398632 1.00E-06 0x00 0x00
SPI result 3.07398872 1.00E-06 0x1E 0xFA
SPI result 3.07399108 1.00E-06 0xAC 0xFA
SPI result 3.07399345 1.00E-06 0x02 0x05
SPI disable 3.07399617 4.00E-09
SPI enable 3.07402873 4.00E-09
SPI result 3.07403012 1.00E-06 0x00 0x00
SPI result 3.07403252 1.00E-06 0x1F 0xFA
SPI result 3.07403488 1.00E-06 0xAC 0xFA
SPI result 3.07403725 1.00E-06 0x02 0x05
SPI disable 3.07403997 4.00E-09
SPI enable 3.0740726 4.00E-09
SPI result 3.07407398 1.00E-06 0x00 0x00
SPI result 3.07407638 1.00E-06 0x1E 0xFA
SPI result 3.07407875 1.00E-06 0xCC 0xFA
SPI result 3.07408111 1.00E-06 0x02 0x05
SPI disable 3.07408383 4.00E-09
SPI enable 3.07411639 4.00E-09
SPI result 3.07411778 1.00E-06 0x00 0x00
SPI result 3.07412018 1.00E-06 0x1F 0xFA
SPI result 3.07412254 1.00E-06 0xCC 0xFA
SPI result 3.07412491 1.00E-06 0x02 0x05
SPI disable 3.07412763 4.00E-09
SPI enable 3.07416366 4.00E-09
SPI result 3.07416504 1.00E-06 0x00 0x00
SPI result 3.07416744 1.00E-06 0x1E 0xFA
SPI result 3.07416981 1.00E-06 0xEC 0xFA
SPI result 3.07417217 1.00E-06 0x02 0x05
SPI disable 3.07417489 4.00E-09
SPI enable 3.07420745 4.00E-09
SPI result 3.07420884 1.00E-06 0x00 0x00
SPI result 3.07421124 1.00E-06 0x1F 0xFA
SPI result 3.0742136 1.00E-06 0xEC 0xFA
SPI result 3.07421597 1.00E-06 0x02 0x05
SPI disable 3.07421868 4.00E-09
SPI enable 3.07425148 4.00E-09
SPI result 3.07425287 1.00E-06 0x00 0x00
SPI result 3.07425527 1.00E-06 0x09 0xFA
SPI result 3.07425763 1.00E-06 0x04 0xFA
SPI result 3.07426004 1.00E-06 0xDE 0x05
SPI result 3.07426247 1.00E-06 0xAD 0x00
SPI result 3.07426487 1.00E-06 0xBE 0x00
SPI result 3.07426727 1.00E-06 0xEF 0x00
SPI result 3.07426966 1.00E-06 0xFE 0x00
SPI result 3.07427206 1.00E-06 0xED 0x00
SPI disable 3.07427482 4.00E-09
SPI enable 3.07430795 4.00E-09
SPI result 3.07430933 1.00E-06 0x00 0x00
SPI result 3.07431173 1.00E-06 0x0F 0xFA
SPI result 3.0743141 1.00E-06 0x04 0xFA
SPI result 3.0743165 1.00E-06 0x00 0x05
SPI result 3.07431893 1.00E-06 0x00 0x00
SPI result 3.07432133 1.00E-06 0x00 0x00
SPI result 3.07432373 1.00E-06 0x00 0x00
SPI disable 3.07432648 4.00E-09
SPI enable 3.07436228 4.00E-09
SPI result 3.0743637 1.00E-06 0x00 0x00
SPI result 3.07436609 1.00E-06 0x03 0xFA
SPI result 3.07436846 1.00E-06 0x08 0xFA
SPI result 3.07437082 1.00E-06 0x00 0x05
SPI disable 3.07437355 4.00E-09
SPI enable 3.07440622 4.00E-09
SPI result 3.07440762 1.00E-06 0x00 0x00
SPI result 3.07441002 1.00E-06 0x03 0xFA
SPI result 3.07441239 1.00E-06 0x28 0xFA
SPI result 3.07441476 1.00E-06 0x00 0x05
SPI disable 3.07441748 4.00E-09
SPI enable 3.07445014 4.00E-09
SPI result 3.07445156 1.00E-06 0x00 0x00
SPI result 3.07445396 1.00E-06 0x03 0xFA
SPI result 3.07445632 1.00E-06 0x48 0xFA
SPI result 3.07445869 1.00E-06 0x00 0x05
SPI disable 3.07446141 4.00E-09
SPI enable 3.07449408 4.00E-09
SPI result 3.07449549 1.00E-06 0x00 0x00
SPI result 3.07449788 1.00E-06 0x03 0xFA
SPI result 3.07450025 1.00E-06 0x68 0xFA
SPI result 3.07450262 1.00E-06 0x00 0x05
SPI disable 3.07450534 4.00E-09
SPI enable 3.07453801 4.00E-09
SPI result 3.07453942 1.00E-06 0x00 0x00
SPI result 3.07454182 1.00E-06 0x03 0xFA
SPI result 3.07454418 1.00E-06 0x88 0xFA
SPI result 3.07454655 1.00E-06 0x00 0x05
SPI disable 3.07454927 4.00E-09
SPI enable 3.07458194 4.00E-09
SPI result 3.07458335 1.00E-06 0x00 0x00
SPI result 3.07458575 1.00E-06 0x03 0xFA
SPI result 3.07458811 1.00E-06 0xA8 0xFA
SPI result 3.07459048 1.00E-06 0x00 0x05
SPI disable 3.0745932 4.00E-09
SPI enable 3.07462587 4.00E-09
SPI result 3.07462728 1.01E-06 0x00 0x00
SPI result 3.07462968 1.00E-06 0x03 0xFA
SPI result 3.07463205 1.00E-06 0xC8 0xFA
SPI result 3.07463441 1.00E-06 0x00 0x05
SPI disable 3.0746405 4.00E-09
SPI enable 3.07467326 4.00E-09
SPI result 3.07467468 1.00E-06 0x00 0x00
SPI result 3.07467707 1.00E-06 0x03 0xFA
SPI result 3.07467944 1.00E-06 0xE8 0xFA
SPI result 3.0746818 1.00E-06 0x00 0x05
SPI disable 3.07468453 4.00E-09
SPI enable 3.27487512 4.00E-09
SPI result 3.27487648 1.00E-06 0x00 0x00
SPI result 3.27487888 1.00E-06 0x0F 0xFA
SPI result 3.27488125 1.00E-06 0x00 0xFA
SPI result 3.27488362 1.00E-06 0x00 0x05
SPI result 3.27488602 1.00E-06 0x00 0x00
SPI result 3.27488842 1.00E-06 0x00 0x00
SPI result 3.27489082 1.00E-06 0x00 0x00
SPI disable 3.27489361 4.00E-09
Finally, pretty basic source code showing the example trying to connect (this shows DHCP, also tried specifying the local IP addr but no worky) -
#include <Ethernet.h>
int tInt = B5;
int tRst = B4;
SerialLogHandler logHandler(115200, LOG_LEVEL_INFO);
EthernetClient eClient; // Global instance
byte mac[] = { 0xde, 0xad, 0xbe, 0xef, 0xfe, 0xed };
IPAddress locIP(192, 168, 0, 150);
IPAddress servIP(192, 168, 0, 39);
IPAddress subN (255, 255, 255, 0);
int servPort = 1701;
void setup() {
System.disableFeature(FEATURE_ETHERNET_DETECTION);
pinMode(tInt, OUTPUT); // Since pulled-up, if mult. devc
digitalWrite(tInt, HIGH); // Active low, so leave high
pinMode(tRst, OUTPUT);
digitalWrite(tRst, HIGH);
pinMode(D5, OUTPUT);
// Need pinMode 1st thing! (initSS() w/in Eth.beg)
delay(1000);
Log.info("Defined IP: %s", locIP.toString().c_str());
if (Ethernet.begin(mac) == 0) {
Log.info("Failed to config w/ DHCP");
Log.info("?IP is: %s", Ethernet.localIP().toString().c_str());
} else {
Log.info("Actual IP is: %s", Ethernet.localIP().toString().c_str());
cnxT = true;
And note the repeated output to serial console is IP addr 5.0.0.0.
Any / all help would be greatly appreciated!
