WizFi250 throughput
Hi.
I have such configuration:
Module A: wizfi250 with two tcp servers, configured as Access Point,
Module B: ip camera with data rate about 700 kB,
Module C: android tablet with two tcp clients.
Module B, C connected to module A . Module C get video stream from module B, and some data from module A host (2 kB/s).
Would wizfi250 throughput be enough in such configuration?
In documentation said that wizfi250 support data rate up to 65 MBit/s, but I would like to remove doubts about this.
Hello Georgiy
<65 MBit/s> is just WiFi physical link rate.
is another issue.
Please refer to the below link.
[url]http://wizwiki.net/wiki/doku.php?id=products:wizfi250:wizfi250pg:start#wizfi250_uart_throughput_test_report[/url]
So, max wifi transfer speed is 1.74Mbit/s?
That would not be enough for camera.
Hello Georgiy
—(A. UART)——(WiFi)—
Maybe is over 10Mbit/s(physical rate is 65MBit/s).
But, in above diagram, camera will send the camera-data to WizFi250 via .
So I think that depends more on thatn on .
That is why is under 2 Mbit/s.
Hello ssekim!
The diagram is —(WiFi)——(WiFi)—.
So no uart here, and throughput is quite enough.
Thank you!
Hello Georgiy
In fact, I didn’t test throughput without UART interface.
But, I believe that it would be more than what you expected.
