Example arduino codes for HTTPS GET/POST
Hello i currently have the W5500-EVB-Pico, and i would like to connect to AWS IoT via HTTPS (not MQTT). I already have the server setup, and i also have the certificates with me. But im having trouble looking for example codes of the W5500 module doing a HTTPS POST/GET, I am currently working on the arduino platform using Earle Philhower core. Can anyone point me to guides on how to set up the certificates?
Thank you
I found a good one
but the example code is generating some errors
#include <SPI.h>
#include <Ethernet.h>
#include <SSLClient.h>
#include "certificates.h"
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
//char server[] = "www.google.com";    // name address for Google (using DNS)
char server[] = "httpbin.org";  // name address for Google (using DNS)
const int rand_pin = A0;
// Set the static IP address to use if the DHCP fails to assign
#define MYIPADDR 192,168,1,28
#define MYIPMASK 255,255,255,0
#define MYDNS 192,168,1,1
#define MYGW 192,168,1,1
EthernetClient base_client;
SSLClient client(base_client, TAs, (size_t)TAs_NUM, rand_pin);
// Variables to measure the speed
unsigned long beginMicros, endMicros;
unsigned long byteCount = 0;
bool printWebData = true;  // set to false for better speed measurement
void setup() {
  Serial.begin(115200);
  while (!Serial) { delay(100); };
  Serial.println("Begin Ethernet");
  Ethernet.init(17);  // Raspberry Pi Pico with w5500
  if (Ethernet.begin(mac)) {  // Dynamic IP setup
    Serial.println("DHCP OK!");
  } else {
    Serial.println("Failed to configure Ethernet using DHCP");
    // Check for Ethernet hardware present
    if (Ethernet.hardwareStatus() == EthernetNoHardware) {
      Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
      while (true) {
        delay(1);  // do nothing, no point running without Ethernet hardware
    if (Ethernet.linkStatus() == LinkOFF) {
      Serial.println("Ethernet cable is not connected.");
    IPAddress ip(MYIPADDR);
    IPAddress dns(MYDNS);
    IPAddress gw(MYGW);
    IPAddress sn(MYIPMASK);
    Ethernet.begin(mac, ip, dns, gw, sn);
    Serial.println("STATIC OK!");
  delay(5000);
  Serial.print("Local IP : ");
  Serial.println(Ethernet.localIP());
  Serial.print("Subnet Mask : ");
  Serial.println(Ethernet.subnetMask());
  Serial.print("Gateway IP : ");
  Serial.println(Ethernet.gatewayIP());
  Serial.print("DNS Server : ");
  Serial.println(Ethernet.dnsServerIP());
  Serial.println("Ethernet Successfully Initialized");
  // if you get a connection, report back via serial:
  if (client.connect(server, 443)) {
    Serial.print("connected to ");
    // Make a HTTP request:
    client.println("GET /get HTTP/1.1");
    client.println("Host: httpbin.org");
    client.println("Connection: close");
    client.println();
  } else {
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  beginMicros = micros();
void loop() {
  // if there are incoming bytes available
  // from the server, read them and print them:
  int len = client.available();
  if (len > 0) {
    byte buffer[80];
    if (len > 80) len = 80;
    client.read(buffer, len);
    if (printWebData) {
      Serial.write(buffer, len);  // show in the serial monitor (slows some boards)
    byteCount = byteCount + len;
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    endMicros = micros();
    Serial.println();
    Serial.println("disconnecting.");
    client.stop();
    Serial.print("Received ");
    Serial.print(byteCount);
    Serial.print(" bytes in ");
    float seconds = (float)(endMicros - beginMicros) / 1000000.0;
    Serial.print(seconds, 4);
    float rate = (float)byteCount / seconds / 1000.0;
    Serial.print(", rate = ");
    Serial.print(rate);
    Serial.print(" kbytes/second");
    Serial.println();
    // do nothing forevermore:
    while (true) {
      delay(1);
Console Logs
Local IP : 192.168.0.45
Subnet Mask : 255.255.255.0
Gateway IP : 192.168.0.1
DNS Server : 192.168.0.1
(SSLClient)(SSL_ERROR)(connect): Failed to connect using m_client. Are you connected to the internet?
connection failed
(SSLClient)(SSL_ERROR)(available): Cannot operate if the write error is not reset:
(SSLClient)(SSL_ERROR)(m_print_ssl_error): SSL_CLIENT_CONNECT_FAIL
(SSLClient)(SSL_ERROR)(connected): Not connected because write error is set
disconnecting.
Received 0 bytes in 0.0005, rate = 0.00 kbytes/second
