(증상)
우선 증상은 위와 같이 wireshark에서 볼 때, W5500에서 송신한
"Who has 192.168.100.210"에 대한 응답을 PC(Hercules)측에서
“192.168.100.210” is at "00:d8:61:e2:7d:03"으로 응답을 하는 것을 계속 반복합니다.
→ 위 결과로 TCP_Connet가 되지 않음.
The MAC address you have chosen is LAA (0x12). No idea how it impacts the workflow, but you can try changing it to UAA. Your screenshots suggest that W5500 does not even try to connect to the server, however it depends on where you have Wireshark listening to traffic. ARP is broadcast, while SYN is unicast, and if you listen on another device than W5500 and server you may not see targeted traffic.
