Weird SPI Behaviour with the W5500 and STM32
Hi all, I have been struggling with the SPI interfacing of this chip in combination with the STM32L412KB. I am using an ETH WIZ Click mikro 3 w5500 board.
After a whole while of getting nonesense numbers from the spi (it almost always returned 15 for some reason). I now got more promising results and decided to test the SPI by running the getversion command. However this value is not just, I receive a 0x2. or a decimal 2. Instead of the expected 0x04.
Now I am unsure wether my code is working alright, hence why I am asking for help here.
On another note, the link stat light is a constant orange, and the CRS occaisionally blinks when connected to a network. Does this mean a succesfull link? I am thrown off by the colour being orange instead of green… I think it could help if I can print all incoming data on the chip, like handshakes etc. Yet I am having trouble realizing that. Please find attached the below code and the MCU configuration.
One theory I have is that in the manual it states that the CS pin is a pullup. Yet I configure my GPIO CS as a non pullup. Is this something that could hinder the SPI? I much rather thought it had to do with how the CS pin is configured internally, rather than what the controlling pin should be.
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "wizchip_conf.h"
#include "stdio.h"
#include "socket.h"
#include "w5500.h"
#include "loopback.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
CRC_HandleTypeDef hcrc;
SPI_HandleTypeDef hspi1;
UART_HandleTypeDef huart2;
volatile wiz_NetInfo gWIZNETINFO =
{0x00, 0x14, 0xA3, 0x75, 0x20, 0x3f}, // Source Mac Address
{192, 168, 1, 100}, // Source IP Address
{255, 255, 0, 0}, // Subnet Mask
{192, 168, 1,1}, // Gateway IP Address
{8, 8, 8, 8}, // DNS server IP Address
NETINFO_DHCP
volatile wiz_PhyConf phyConf =
PHY_CONFBY_HW, // PHY_CONFBY_SW
PHY_MODE_AUTONEGO, // PHY_MODE_AUTONEGO
PHY_SPEED_100, // PHY_SPEED_100
PHY_DUPLEX_FULL, // PHY_DUPLEX_HALF
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_CRC_Init(void);
static void MX_USART2_UART_Init(void);
static void MX_SPI1_Init(void);
#define VERSIONR           (0x00000000 + (0x0039 << 8) + (0x00 << 3))
/* USER CODE BEGIN PFP */
void cs_sel() {
HAL_GPIO_WritePin(GPIOA, cs_Pin, GPIO_PIN_RESET); //CS LOW
void cs_desel() {
	HAL_GPIO_WritePin(GPIOA, cs_Pin, GPIO_PIN_SET); //CS HIGH
uint8_t spi_rb(void) {
	uint8_t rbuf;
	HAL_SPI_Receive(&hspi1, &rbuf, 1, 0xFFFFFFFF);
	return rbuf;
void spi_wb(uint8_t b) {
	HAL_SPI_Transmit(&hspi1, &b, 1, 0xFFFFFFFF);
void print_network_information(void)
	memset(&gWIZNETINFO,0,sizeof(gWIZNETINFO));
	wizchip_getnetinfo(&gWIZNETINFO);
	printf("MAC Address : %02x:%02x:%02x:%02x:%02x:%02x\n\r",gWIZNETINFO.mac[0],gWIZNETINFO.mac[1],gWIZNETINFO.mac[2],gWIZNETINFO.mac[3],gWIZNETINFO.mac[4],gWIZNETINFO.mac[5]);
	printf("IP  Address : %d.%d.%d.%d\n\r",gWIZNETINFO.ip[0],gWIZNETINFO.ip[1],gWIZNETINFO.ip[2],gWIZNETINFO.ip[3]);
	printf("Subnet Mask : %d.%d.%d.%d\n\r",gWIZNETINFO.sn[0],gWIZNETINFO.sn[1],gWIZNETINFO.sn[2],gWIZNETINFO.sn[3]);
	printf("Gateway     : %d.%d.%d.%d\n\r",gWIZNETINFO.gw[0],gWIZNETINFO.gw[1],gWIZNETINFO.gw[2],gWIZNETINFO.gw[3]);
	printf("DNS Server  : %d.%d.%d.%d\n\r",gWIZNETINFO.dns[0],gWIZNETINFO.dns[1],gWIZNETINFO.dns[2],gWIZNETINFO.dns[3]);
uint8_t gDATABUF[1024];
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
	  reg_wizchip_cs_cbfunc(cs_sel, cs_desel);
	  reg_wizchip_spi_cbfunc(spi_rb, spi_wb);
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_CRC_Init();
  MX_USART2_UART_Init();
  MX_SPI1_Init();
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
   set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  /* USER CODE BEGIN 2 */
  printf("\n\r UART Printf Example: retarget the C library printf function to the UART\n\r");
  uint8_t rcvBuf[20], bufSize = {16, 0, 0, 0, 0,0,0,0};
  HAL_GPIO_WritePin(GPIOA, reset_Pin, GPIO_PIN_SET);
  HAL_Delay(400);
  HAL_GPIO_WritePin(GPIOA, reset_Pin, GPIO_PIN_RESET);
  HAL_Delay(2000);
  wizchip_init(bufSize, bufSize);
  ctlnetwork(CN_SET_NETINFO, (void*) &gWIZNETINFO);
  HAL_Delay(500);
  ctlwizchip(CW_SET_PHYCONF, (void*) &phyConf);
  HAL_Delay(500);
  uint8_t x = WIZCHIP_READ(VERSIONR);
  printf("\n\r %d \n\r", x);
  wizchip_setnetmode(NM_WAKEONLAN);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  printf("\n\rsetup complete\n\r");
  print_network_information();
  while (1)
    /* USER CODE END WHILE */
//	  for (int i=0;i < (sizeof (rcvBuf) /sizeof (rcvBuf[0]));i++) {
//	      printf("%d\n",rcvBuf[i]);
	  HAL_Delay(1000);
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART1 and Loop until the end of transmission */
  HAL_UART_Transmit(&huart2, (uint8_t *)&ch, 1, 0xFFFF);
  return ch;
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
    Error_Handler();
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 1;
  RCC_OscInitStruct.PLL.PLLN = 10;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
    Error_Handler();
  * @brief CRC Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN CRC_Init 0 */
  /* USER CODE END CRC_Init 0 */
  /* USER CODE BEGIN CRC_Init 1 */
  /* USER CODE END CRC_Init 1 */
  hcrc.Instance = CRC;
  hcrc.Init.DefaultPolynomialUse = DEFAULT_POLYNOMIAL_ENABLE;
  hcrc.Init.DefaultInitValueUse = DEFAULT_INIT_VALUE_ENABLE;
  hcrc.Init.InputDataInversionMode = CRC_INPUTDATA_INVERSION_NONE;
  hcrc.Init.OutputDataInversionMode = CRC_OUTPUTDATA_INVERSION_DISABLE;
  hcrc.InputDataFormat = CRC_INPUTDATA_FORMAT_BYTES;
  if (HAL_CRC_Init(&hcrc) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN CRC_Init 2 */
  /* USER CODE END CRC_Init 2 */
  * @brief SPI1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN SPI1_Init 0 */
  /* USER CODE END SPI1_Init 0 */
  /* USER CODE BEGIN SPI1_Init 1 */
  /* USER CODE END SPI1_Init 1 */
  /* SPI1 parameter configuration*/
  hspi1.Instance = SPI1;
  hspi1.Init.Mode = SPI_MODE_MASTER;
  hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi1.Init.NSS = SPI_NSS_SOFT;
  hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_16;
  hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi1.Init.CRCPolynomial = 7;
  hspi1.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
  hspi1.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
  if (HAL_SPI_Init(&hspi1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN SPI1_Init 2 */
  /* USER CODE END SPI1_Init 2 */
  * @brief USART2 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN USART2_Init 0 */
  /* USER CODE END USART2_Init 0 */
  /* USER CODE BEGIN USART2_Init 1 */
  /* USER CODE END USART2_Init 1 */
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  huart2.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART2_Init 2 */
  /* USER CODE END USART2_Init 2 */
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOA, cs_Pin|reset_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pins : cs_Pin reset_Pin */
  GPIO_InitStruct.Pin = cs_Pin|reset_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
Schermafbeelding 2024-04-10 102739
SPI is configured like so:
Schermafbeelding 2024-04-10 105040
Should this be 8 bits?
and 40 Mbps on the SPI is too much for the W5500, try making it work at 8 MHz for now
You are right, this was legacy. My apologies. I have adjusted my question.
I lowered the baudrate and adjusted to 8 bit size. Still no improvement.
I have managed to restructure my code, according to other very old posts i found that the order in which initilaizers are called matters. I have now made the following which works with ping.
  * @file           : main.c
  * @attention
#include "main.h"
#include "w5500_spi.h"
wiz_NetInfo gWIZNETINFO = {
	  .mac = {0x00, 0x08, 0xdc, 0xab, 0xcd, 0xef},
			  .ip = {zzzz},
			  .sn = {255, 255, 255, 0},
			  .gw = {zzzzzz},
			  .dns = {8, 8, 8, 8},
			  .dhcp = NETINFO_DHCP};
void cs_sel() {
void cs_desel() {
	uint8_t rbuf;
	return rbuf;
  * @retval int
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  MX_CRC_Init();
  MX_SPI1_Init();
#ifdef __GNUC__
#else
  HAL_Delay(400);
  HAL_Delay(2000);
  W5500Init();
  HAL_Delay(500);
  //ctlwizchip(CW_SET_PHYCONF, (void*) &phyConf);
  HAL_Delay(500);
  /* Infinite loop */
  while (1)
	  HAL_Delay(1000);
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
    Error_Handler();
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
  * @param None
  * @retval None
    Error_Handler();
  * @param None
  * @retval None
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
I have been working on writing a driver for the W5500 specifically for the STM32F4 that I have. There are some nuisances I discovered that has caused me a lot of wasted time troubleshooting the issue. One of them is the clock speed of the MCU. Anything above 32 MHz CPU causes some corruption on received data from the W5500. I can make it work at 168MHz with 21MHz SPI but it’s not stable and would have data corruption after tens of thousands of packets transmitted and received. Enabling the Instruction and Data Cache (DCACHE and ICACHE) feature of the STM32 also causes issue with SPI communication. Tried adding delay between Slave_Select activation and SPI byte sends doesn’t help either. Even running the CPU at 168MHz and SPI at 1MHz or below don’t work either so I’m not sure what the problem is.
Currently, I have it running at 32MHz CPU and 16MHz SPI with no DCACHE, ICACHE enabled and been able to TX and RX 2.2 million packets of about 3.2 GBytes of data with zero data corruption from the Linux client so far (1.3 Mbps TX/RX)
Just some things to keep in mind when working with the STM32 and W5500 combo.
My educated and experienced guess says the problem lies in the SPI relative signal timing (hold/setup timing violations).
That’s what I thought too so I tried adding delays between SPI byte operations
I have tried something like this
func read_reg()
	SS_LOW
	delay();
	SPI_send addr_H
	delay();
	SPI_send addr_L
	delay();
	SPI_send OPCODE_byte
	delay();
	SPI_read reply_byte
	SS_HIGH;
The datasheet specifies like 3 or 5 ns minimum for most of these “delays”
The thing that I found out is, if the SPI is not working, i received the byte sequence from the SPI_RECV at
0x00, 0x01, 0x02, 0x03
instead of
0x01, 0x02, 0x03, 0x04
So when I’m reading the VERSION register, I get a 0x03 instead of 0x04
The evil could be in SPI_send and SPI_read - in delays between toggling and reading signals relative to each other. I can’t say more because do not know how they are implemented in your platform.
Which datasheet? 5 ns is 200 MHz, and sounds to be insane for W5500 SPI communication.
I was talking about section 5.5.4 “SPI TIMING” of the Wiznet W5500 V1.1.0 ref guide
I’m using basic baremetal implementation of the SPI peripheral for my STM32F4
static uint8_t ssp1_read_register(uint8_t BSB, uint16_t offsetAddress)
	uint8_t rtn = 0;
	uint8_t tH = 0;
	uint8_t tL = 0;
	W5500_SS_LO;
	tH = (uint8_t) ((offsetAddress & 0xFF00) >> 8U);
	tL = (uint8_t) ((offsetAddress & 0x00FF) >> 0U);
	SPI2->DR = tH;
	while((SPI2->SR & SPI_SR_TXE_Msk) == 0);
	rtn = SPI2->DR;
	SPI2->DR = tL;
	rtn = SPI2->DR;
	SPI2->DR = BSB | W5500_OPCODE_READ;
	rtn = SPI2->DR;
	SPI2->DR = DUMMY_BYTE;
	rtn = SPI2->DR;
	W5500_SS_HI;
	return rtn;
This works at anything below 32MHz CPU and upto max SPI of 16MHz. Anything above 32 MHz CPU, I have to put in short delays between byte transfers, and even that is unreliable so I’m not quite sure what else can be done.
These values are minimal when you connnect your MCU’s input directly to W5500 die-to-die. In reality you have transmission line subject to capacitance and inductance, which will make these times longer. Consider 2x derating for these times if you make hardware right.
Take scope to see what is going on in the SPI bus. Better multi-channel scope to see the relative positioning of the waveforms. The next steps will depend on what you see. Digging into the features of the MCU SPI implementation may be a good idea to see what you can tune (if it is possible at all). You may also search MCU forum or ask question there. It may appear problem is not purely W5500-related.
