Version Number does not get displayed succesfully
Hi all,
I have a small problem with my W5500 chip. I had successfully written code for it before, and have reused the same logic parts for this. However, nothing works. And i am a bit stuck as to why.
Below is my code, one thing that i noticed is that my RST pin seems to be high all the time. Even after the reset. This might mess with things? Please let me know your thoughts.
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "w5500_spi.h"
#include "wizchip_conf.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
SPI_HandleTypeDef hspi1;
/* USER CODE BEGIN PV */
wiz_NetInfo gWIZNETINFO = {
	  .mac = {0x00, 0x08, 0xdc, 0xab, 0xcd, 0xef},
			  .ip = {192,168,1,10},
			  .sn = {255, 255, 255, 0},
			  .gw = {10, 1, 64, 1},
			  .dns = {8, 8, 8, 8},
			  .dhcp = NETINFO_DHCP};
wiz_NetInfo gWIZNETINFO2 = {
			  .ip = {10, 1, 64, 11},
			  .dhcp = NETINFO_STATIC};
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_SPI1_Init(void);
/* USER CODE BEGIN PFP */
void cs_sel() {
HAL_GPIO_WritePin(GPIOA, cs_Pin, GPIO_PIN_RESET); //CS LOW
void cs_desel() {
	HAL_GPIO_WritePin(GPIOA, cs_Pin, GPIO_PIN_SET); //CS HIGH
uint8_t spi_rb(void) {
	uint8_t rbuf;
	HAL_SPI_Receive(&hspi1, &rbuf, 1, 0xFFFFFFFF);
	return rbuf;
void spi_wb(uint8_t b) {
	HAL_SPI_Transmit(&hspi1, &b, 1, 0xFFFFFFFF);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
	//reg_wizchip_cs_cbfunc(cs_sel, cs_desel);
		//  reg_wizchip_spi_cbfunc(spi_rb, spi_wb);
	  /* USER CODE BEGIN 1 */
	  /* USER CODE END 1 */
	  /* MCU Configuration--------------------------------------------------------*/
	  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
	  HAL_Init();
	  /* USER CODE BEGIN Init */
	  /* USER CODE END Init */
	  /* Configure the system clock */
	  SystemClock_Config();
	  /* USER CODE BEGIN SysInit */
	  /* USER CODE END SysInit */
	  /* Initialize all configured peripherals */
	  MX_GPIO_Init();
	  MX_SPI1_Init();
	#ifdef __GNUC__
	/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
	   set to 'Yes') calls __io_putchar() */
	#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
	#else
	#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
	#endif /* __GNUC__ */
	  /* USER CODE BEGIN 2 */
	  printf("\n\r UART Printf Example: retarget the C library printf function to the UART\n\r");
	  uint8_t rcvBuf[20], bufSize = {16, 0, 0, 0, 0,0,0,0};
	  HAL_GPIO_WritePin(GPIOA, reset_Pin, GPIO_PIN_SET);
	  HAL_Delay(1000);
	  HAL_GPIO_WritePin(GPIOA, reset_Pin, GPIO_PIN_RESET);
	  W5500Init();
	  wizchip_init(16, 16);
	  //ctlnetwork(CN_SET_NETINFO, (void*) &gWIZNETINFO);
	  uint8_t x = WIZCHIP_READ(VERSIONR);
	  uint8_t  rxbuf[10];
	  uint8_t addr = 0x0039;
	  WIZCHIP_READ_BUF(addr, &rxbuf, 3);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
    Error_Handler();
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
  RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  RCC_OscInitStruct.MSICalibrationValue = 0;
  RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
  RCC_OscInitStruct.PLL.PLLM = 1;
  RCC_OscInitStruct.PLL.PLLN = 40;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV7;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
    Error_Handler();
  * @brief SPI1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN SPI1_Init 0 */
  /* USER CODE END SPI1_Init 0 */
  /* USER CODE BEGIN SPI1_Init 1 */
  /* USER CODE END SPI1_Init 1 */
  /* SPI1 parameter configuration*/
  hspi1.Instance = SPI1;
  hspi1.Init.Mode = SPI_MODE_MASTER;
  hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi1.Init.NSS = SPI_NSS_SOFT;
  hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
  hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi1.Init.CRCPolynomial = 7;
  hspi1.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
  hspi1.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
  if (HAL_SPI_Init(&hspi1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN SPI1_Init 2 */
  /* USER CODE END SPI1_Init 2 */
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOA, reset_Pin|cs_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pins : reset_Pin cs_Pin */
  GPIO_InitStruct.Pin = reset_Pin|cs_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
You’d better reset chip using reset pin properly as advised in the datasheet.
This does not help, you must give details what and how exactly it does not work, and how you believe it must work. If you reused the code and it was working within previous hardware, then logically, as you guess, something has changed in the hardware - try comparing the circuit diagrams.
