Helo All,
I want to use WIZ100SR for uploading some data to a website. There will be a microcontroller based unit which interface with WIZ100SR. The WIZ100SR will be plugged to local LAN which is connected to Internet.
I need to send a data that looks something like this:
medidatabase.com/upload.asp? … d=thatword
When I type this data on the address space of a web browser (running on a PC connected to LAN) it is transmitted correctly and I get a message back “YES” which is shown on the browser.
I am very much confused how to do this using WIZ100SR. I am also not sure whether WIZ100SR is the right choice for this. Can somebody give guidelines?
First Should I configure WIZ100SR and then only attach to the microcontroller PCB? If so how should I configure?
What the microcontroller should do to send the above mentioned data?
