hi
whats input data format of w5100?
and how its programming? through spi? and how data communicated between input and w5100?
kavireloot
For the communication with MCU, W5100 provides Direct Bus I/F, Indirect Bus I/F, SPI I/F mode.
and for the communication with Ethernet PHY, MII is used.
For more information, please click on the URL as below.
DataSheet : [url]http://www.wiznet.co.kr/Admin_Root/UpLoad_Files/BoardFiles/W5100_Datasheet_v1.2.5.pdf[/url]
thanks,
EK
ok.but my question is what dose kind of data input? stream,binary or …???
Sorry, kavireloot
Direct/Indirect BUS I/F → each time a byte is transmitted.
SPI I/F → each time a bit is transmitted.
thanks,
EK
W5100 data format is not fixed.
Don’t care the data format - binary or ASCII.
W5100 will send the data to be written by you or W5100 will receive the data to be written by a peer.
thanks for your response…
