Hi
We are using W5200 in TCP mode.
Our devices are not working in Layer 2 switches.
How can we do?
Should we require to write additional source code to work layer 2 switches?
Selahattin Aslan
Hi
How can we do?
Selahattin Aslan
Hi! selaslan,
What kind of product did you use? W5200 chip or WIZ820io?
To check some physical layer problem, you need to check the Link LED in your system.
If the Link LED is blinking the physical link is good. There would be another issue.
Can you draw your system block diagram you made?
Thank you,
Kevin
We are testing Planet SGSW-24040R manageble switch
W5200 is not working
But we have other hardware based W5100 design. It’s working
We have applied Erratum 1, but still it is not working
What is the problem?
We have upgraded our new designs with W5200. But many devices are returned back with this problem.
Selahattin
Hi
We are using W5200 IC in our hardware
BTW, Link led is blinking. No problem
If we use basic switch (non-managable) W5200 is working
But If we use manageble switch (Planet SGSW-24040R) There is no connection.
We have received this feadback about this problem from other customers with different switches
In addition,
The interesting thing is our previous desing based on W5100 is working good. I do not understand.
Rgds
Hi Again
As I check, If we plug 1000 base-T switches, the blink rate is little bit slowing
I mean the blink rate is different between 100base_T and 1000 base_T
And I saw some post reported There is a problem of early W5200 ICs in gigabit switches
In this case, We have purchased about 1200 pcs, and really on trouble
How can we change the ICs?
Rgds
Selahattin Aslan
Did you mean you connect W5200 to 1000 base_T switch then LED is blinking slow rate??
it is too hard to decide that it’s not working just LED is blinking slow rate.
It could take longer about negotiation.
So check link register and after it is set, test data transferring.
Hi
We already test all, data transferring is also ok.
We have debugged data packages via managable switch diagnostic
Btw, we saw that the switch could not learned the mac addres of w5200 device
But it learned the mac address of w5100 devices successfully
In 100 mbps non managable switchs, both are ok
Our w5200 chips datecode is 1348
We doubt that our w5200 are early production and have problem with managable gigabit switches
Awaiting your solution
Selahattin
Hi
PHY register content is 0x37
Link status register is 1 (Link Up)
Selahattin
We saw the problem and solved
We have extended the rcr timeot value
But there is another issue
The managable switch can not learn the mac
Address of w5200 device when we plug the cable,
if i get connection to the w5200 device from a PC
The managable switch is leraning mac addres
But if we plug the cable of w5100 device, the managable switch is
learning the mac address even there is no connection
I tnink w5200 is not responding to incoming ARP request from managable switch
Awaiting reply
Selahattin
[quote]But if we plug the cable of w5100 device, the managable switch is
learning the mac address even there is no connection[/quote]
It means if W5100 or W5200<---->switch, switch sends ARP request and makes MAC table??
As I know, switch learns MAC address when server or client try to send some packet to destination.
i.e. W5200 try to send data to PC via switch(W5200 <-----> switch <----> PC).
