Does Ethernet Link LED turn on?
Does Ethernet Act LED blinking normally?
If your answer is yes for above question,
Try factory reset to WIZ1000.
[color=#FFFFFF]…[/color]a. Turn on WIZ1000
[color=#FFFFFF]…[/color]b. After boot up, press the reset button while 5~10 seconds
[color=#FFFFFF]…[/color]c. Release the reset button.
[color=#FFFFFF]…[/color]d. WIZ1000 will print “Factory default” message via serial and then reboot.
Turn off all of firewall on your PC.
Disable all of Ethernet Controller without one(connected with WIZ1000).
[attachment=0]2015-01-05 오전 8-45-17.png[/attachment]
If you still face problem, please contact reseller to replace the new product.
Hi. Will the configuration tool be able to recognize my WIZ1000 even if there is no serial device connected (serial device is not yet available)? I am trying to configure my WIZ1000 and I don’t know where to start. I only connected the WIZ1000 to my laptop using the ethernet cable. Your reply will be greatly appreciated!
