I saw the example give on the webclient. it is using http get instead of post.
i want to the arduino uno + wizfi shield to send data to the carriots. Can i get some guide on http post for webclient?
There is HTTP-PUT example as below.
Even though it’s not HTTP-POST, I believe that you can refer it.
This is the example for webclient using http post.
“Ubidots.com” offer this example. [url]Connect an Arduino UNO + WIZnet WizFi250 to Ubidots over HTTP | Ubidots Help Center
But, source code was little modified.
Simple example using WizFi device
This example was made using an example of the original library and was modified to work with tje Ubidots platform.
This sketch connects to Ubidots (http://www.ubidots.com) using an WizNet Shield
Components:
* WizFi Hardware
* Arduino UNO
* WizFi250 library
Modified 15 Sep 2014
by Mateo Vélez - Metavix - for Ubidots Inc.
This code is in the public domain.
// Modified by Daniel
#include <Arduino.h>
#include <SPI.h>
#include "WizFi250.h"
#include "WizFi250_tcp_client.h"
#define SSID "iptime"
#define KEY ""
#define AUTH "OPEN"
#define REMOTE_PORT 80
#define LOCAL_PORT 5004
IPAddress destIP (50,23,124,68); //ip of the server
WizFi250 wizfi250;
WizFi250_TCP_Client myClient;
boolean Wifi_setup = false;
//The setup function is called once at startup of the sketch
void setup()
// Add your initialization code here
Serial.begin(9600);
Serial.println("\r\nSerial Init");
wizfi250.begin();
wizfi250.setDebugPrint(4);
wizfi250.hw_reset();
wizfi250.sync();
wizfi250.setDhcp();
for(int i=0; i<10; i++)
if( wizfi250.join(SSID,KEY,AUTH) == RET_OK )
Wifi_setup = true;
break;
void loop()
//Add your repeated code here
uint8_t retval=0, len=0;
uint8_t ch;
uint8_t Txbuf[250];
int data = analogRead(A0);
char post_data_buf[32];
snprintf(post_data_buf, sizeof(post_data_buf), "{\"value\": %d}\r\n", data);
if( Wifi_setup )
wizfi250.RcvPacket();
if( myClient.available() )
ch = myClient.recv();
if(ch != NULL)
Serial.print((char)ch);
else
myClient = WizFi250_TCP_Client(destIP, REMOTE_PORT);
retval = myClient.connect();
if(retval == RET_OK)
//change the "xxxxx..."" with your variable id and "yyyy..." with your token
Serial.println("Connected! ");
sprintf((char*)Txbuf,"POST /api/v1.6/variables/xxxxxxxxxxxxxxxxx/values HTTP/1.1\r\nContent-Type: application/json\r\nContent-Length: %d\r\nX-Auth-Token: yyyyyyyyyyyyyyyyyyy\r\nHost: things.ubidots.com\r\n\r\n%s\r\n",strlen(post_data_buf),post_data_buf);
myClient.send((uint8_t*)Txbuf,sizeof(Txbuf));
Serial.println((char*)Txbuf);
