I am developing a program for a control system using Arduino and Internet Shield with W7100 chip. My programm is written in c# and using the common libery (TcpClient) as communication interface. The program is work fine but if I try to connect the controller with multiple client simutantly (all client connect to the same server - same IP and same port-), only the first client can connect to server. As i see in the detial of W7100, it should be connected up to 8 sockets (= 8 clients?).
My Question :
- Is it possible for multiple clients to connect to the server at the same time?
- Do I have to set the socket number to make this situation possible? - if yes, how can I set it in c#?
Thanks,
zensuie
