i am a new user of W530
in the sw i sent a reset after a hardware reset,
write the source IP, PORT,SUBNETMASK(255.255.255.0),
put soket0 to TCP mode,open the socket, and i receive sock init status.
then i put the listen command but no established happened.
what i am missing?
if some one can send me an example , what is the correct way to program the device as server.
I need more information.
- Was link led blinking?
- How did you connect? W5500 - PC Directly? or Use AP?
- If you try to connect over the internet, you have to put the official mac address.
