I have now purchased the W5500-EVB board for evaluation. Once the evaluation stage is over I need to buy W5500 in large quantities once the board goes for production.
I have the requirement of interfacing an FPGA board with the W5500-EVB. I need to send the FPGA output data over Ethernet. The other project requirement is to make our prototype work as an FTP server.
Kindly provide us technical support on this aspect ASAP. Please route this email to the concerned technical person to whom I can interact with.
WIZnet just supports the C-level source code for W5500.
If you want to FPGA FTP Server, you shoud developement W5500 driver and FTP server by using HDL language, by yourself.
WIZnet just can advice to you.
During developmenting them, If you need a help, feel free to post it on this forum.
No I don’t want to implement FTP server inside the FPGA.
I am trying to implement FTP server outside the FPGA by using LPC11E36 processor and W5500 chip.
I wanted to pass the FPGA output bits over Ethernet.
If i compile and implement the C codes available from Github on to LPC11E36 processor, will that get configured automatically?
Once the FTP server link is established, can i pass the FPGA output bits to LPC11E36 processor using SSP interface?
I need the method of interfacing FPGA to (LPC11E36 processor + W5500 chip).
So please assist.
ANS:
I think it can. If you implement like SSP interface using FPGA, you can control W5500.
SSP frame is explained at datasheet. You need to generate like that signal using FPGA.
i got wiznet w5500 Ethernet module schematic, i am trying to designed same.
but facing some issues…
I am a new bee for this design technology , can any one guide me for the same.
I stuck in hardware issue,
Since I am designing a small PCB board there is a confusions in design
1) RJ45 Connector pin 8 is GND in some design do i need to make it GND are leave it
2) please guide me where are the important Testpoints required for testing the signals
3) since i am using LM2576 3.3V Regulator for this design is it sufficient for the design
4) since i need to design a Small PCB please give us an inputs that what should be the size of the design and signal length and any important points for designing PCB
5) i am designing this PCB for 2layer is it sufficient are need to go for another layer please guide me
I need to attach my Schematic please guide me how to attach file
we had purchased a W5500 EVB module for one of our project,
its working fine we need to include that in our module hence we go for a PCB design in that there is a communication problem,
with the help and support of SCOTT we went to design a new small PCB design in this New PCB LINKLED and ACTLED are blinking properly but there is now data communication,
please guide me on this how to solve this issue we are waiting for your reply,
We have purchased the W5500-EVB board for an Ethernet based project. We are planning to interface FPGA(Spartan 3 or Spartan 6) with an Ethernet(W5500) module. We want to display some sensor based data on web from FPGA and from webpage to FPGA for further processing. After completing the project we want to buy more W5500 modules to develop a network of sensor nodes.
The major requirement is interfacing an FPGA board with the W5500-EVB. I need to send the FPGA output data over Ethernet as an HTTP webpage.
Kindly provide us with your support on this and suggest some ideas to deal with the project. Please send this email to the concerned person with whom I can interact.
