Because of your Suggest in your QnA-Answer to use this Forum, i transfer my Issue to this Thread.:
Hello!
All commands used so far (except the “GF”-Command) work correctly.
And as I tried to mention:
The “GF”-Command correctly adds a specific Profile, but doesn’t activate it. …It doesn’t log in to the Wifi which is specified by the Profle.
Kind regards,
Christian Grunbacher
[quote]
Dear customer.
Thanks for your interest in WizFi630.
Please, confirm all command doesn’t work or specific command you said doesn’t work.
P.S. : We open WIZwiki forum.
index.php
We take care of it a lot.
So, use it a lot, please.
WIZnet.
[quote]
Hello!
I need to configure my WizFi630 through the Serial-Command-Interface and stumbled over following Problem:
When Using the Wizfi630 in Client(Station)-Mode, i can’t connect to another Wifi.
→ The Command “GI” can’t be used, because the target-AP broadcasts a WPA-PSK-Network and no WEP
→ The Command “GU” (although it is suggested in the manual) can’t be used in client(station)-Mode.
→ So my only chance to connect is by creating a Profile using the “GF” command.
→ Creating a Profile with the correct settings works, but the WiZi630 doesn’t connect to it…
→ …unless i go to the Web-Interface log in and click on the “Profile” section. (nothing else)
…But i in my Application i have to connect to a Wifi by using serial-commands and no Web-Interface-Inputs.
I would be very thankful if you could help me with this problem!
[/quote][/quote]
