I have reviewed the firmware example code and have verified on my pc that 10M speed is lower current than 100M. I have an application that is low power and I can not control the remote link speed. Can I force my WIZnet550web to use 10M rate in firmware?
Thank You in Advance.
Hi, romanyork.
Force 10M-base link speed is possible.
Please insert below code to the bottom of the function W5500_Init().
wiz_PhyConf phymode;
phymode.by = PHY_CONFBY_SW;
phymode.mode = PHY_MODE_MANUAL;
phymode.speed = PHY_SPEED_10;
phymode.duplex = PHY_DUPLEX_FULL; // Choose PHY_DUPLEX_HALF or PHY_DUPLEX_FULL
ctlwizchip(CW_SET_PHYCONF, &phymode);
Regards,
Eric.
Thanks Eric,
That worked.
Roman
