Hello there,
i have a huge problem accessing the SIPR Register via 16 Bit bus. I can write and read every other register but the SIPR1 register.
But the SIPR1 register always stays 0x0000. With 8 Bit bus mode it works but in 16 Bit bus something´s wrong.
SIPR0 works fine…
Are there any suggestions or similar problems known?
Regards
Roscoe
Hello, Roscoe
There are some reasons make the problem happen.
- I wonder if you use driver for 16bit MCU we provide or use your own driver.
- if MR(Mode Register) is set incorrectly, it happens.
- There are Direct Address Mode and Indirect Address Mode. and both has different pin setting. I suggest you to check w5300 datasheet with them.
- There is Idenrification Register(IDR). If you can read IDR correctly, there is no problem with reading data. So test to read IDR. It initialized with 0x5300.
I can’t check your coding, so I suggest some reasons make it happens.
Check it on with above solutions and let me know.
sincerely,
Lawrence
