Hi all,
I am new to wiznet w5100 and I have done with TCP/IP based Client/server using interrupt.
Now I want to use SEND_KEEP and TIMEOUT for TCP/IP client/server link status. please help me I don’t know how to implement it.
if anybody have sample code then please provide me…
thank you all…
for example.
switch(getSn_SR(sn))
case SOCK_ESTABLISHED:
// check to send keep time
if(is_send_keep_time_elapsed) setSn_CR(sn,Sn_CR_SENDKEEP);
break;
case SOCK_CLOSED:
// if TIMOUT . socket should be closed.
if(getSn_IR(sn) & Sn_IR_TIMEOUT) printf("TIMEOUT");
break;
You can just perform SENDKEEP command with Sn_CR register and check the socket closed & Sn_IR regisiter.
