Hi, I recently bought WIZ550web Baseboard .
I want to know if it is possible to put a password for access through the web ?
Orko :ugeek:
Orko :ugeek:
WIZnet does not provide additional Login webpage and features for WIZ550web product.
If this function is required, you can Implement directly.
Regards,
Eric.
Thanks for your reply.
Please could expand more details about your comment:
“If this function is required, you can Implement directly.”
As it could be implemented directly?
Thanks for your help and suggestions.
Orko
I’m sorry for making you confused.
‘Directly’ means ‘yourself’.
The WIZ550web source code firmware projects and Webpage file is open source.
You can find our code in gitHub repository, github.com/Wiznet/WIZ550web
[quote=“Orko”]Hi, I recently bought WIZ550web Baseboard .
Orko :ugeek:[/quote]
I also agree with Orco, for safety reasons it is necessary to modify the firmware for the possibility of including the password on the Web.
Thank you for good feedback.
we will to review whether adding the login function.
