Connector on WIZ105SR module
Hallo,
I would like to know the recommended connector to the module given in the subject. I have tried to find one at the component dealers but there are a lot to chose from. Please provide information on the female connector both with and without wires.
Best regards
Henrik
Hi Henrik.
We have used a generic 2.00mm pin header connector.
We do not recommend particular connector. You can use the generic 2.00mm connectors.
Look at Google search for “2.00mm female” or “2.00mm pin header female”.
Scott
