I try to connect an UPS to a domain network but there is no way to connect to WIZ110SR. I always see “disconnected” near the IP address.
Here the configuration of the module and of the VSP, what’s wrong?
thankyou in advance
regards
Francesco
thankyou in advance
regards
Francesco
I set WIZVSP software as a client and WIZ110SER as server and this is working good. But I have problem to do it in reverse way it means WIZVSP as a server and WIZ110SER as a client. Could you explain me why it is not working? I did many tests and none was successful. Firewall is not blocking ports for sure because it is working like I wrote at the beginning. What is the reason?
Marcin
