Hi…
I am using WIZ107SR module.
I have installed configuration tool and did search.Its showing MAC address as FF:FF:FF:FF:FF:FF and remaining address as default values.
I am not able to ping the device.
So how I can do this.
Please help me in this.
I am not using evaluation board.
I am having wiznet module.
Can you please explain step 0 (Switch on the H/W Trigger in EVB).
What are all the pins should be connected and to which voltage these pins should be connected.
Is there will be any message after MAC address get re written successfully.
