Wizfi communication
  1. If I want to connect an MCU with Wizfi250 via SPI, should I use 3.3v voltage regulator or the pin are 5v tolerant?
  2. In case of UART connection and I want to use RTC/CTS, are those as well 3.3v?
Thank you,
Best Regards,
Andreas Achilleos
Hi Andreas Achilleos.
As you know, In all situations that were considered, you have to use 3.3v.
