[From QnA] WIZ1000 serial power pin 9
#1
If power is supplied to the normal 5V socket on the WIZ1000 or WIZ6000 can the 5V also be output on the DB9 serial pin 9/4 so that a connect RS232 peripheral also be powered by your module. Obviously the RS232 peripheral will accept the power on pin 9/4.
thank you
#2
Dear customer.
Thanks for your interest in our product.
Is your question that you want to use power from RS232 of WIZ1000 or WIZ6000 ??
We don’t test about that but we think it is possible if don’t use too much current.
WIZnet.
