Is it possible to connect WIZ110SR to an arduino (ardupilot) and use it to transmit data over ethernet, instead of using XBEEs (serial) for the communication.
The pins that are available on ardupilot are the In (RX), Out (TX), +5V and GND.
Dear customer,
Thanks for your interest in Wiz110sr.
If you want to operate data transmission over Ethernet, you are using after operation mode select.
And Wiz110sr can set the baud rate up to 115200.
Thanks,
WIZnet
Thanks for your answer,
Can you please explain what do you mean by " after operation mode select."
Is this the default state? Could not find something like this inside the manual.
Dear customer,
Operation mode means TCP Server or TCP Client or UDP.
You can find out in part the description of the configuration tool in manual.
thanks,
WIZnet
