Precisioin about AT+WCHECK please
Dear,
in the description, you write :
[quote] Format:
AT+WCHECK=,,
Meaning: Check Wi-Fi status using Ping and Re-association with AP
It must be set as service mode in order to use Re-association function.
This function only exist later vision of F/W 1.0.3.5. [/quote]
i don’t find any 1.0.3.5 FW version !.. just 1.0.3.3 then 1.0.4.2 …
is it available on 1.0.3.3 ?
when the 1.0.4.2 will become ‘stable’ version ?
thanks, regards
Hi phil31
As you know, You can just use 1.0.4.2 version for using AT+WCHECK
1.0.3.5 version is a private version because it is too unstable to release.
thanks daniel
then when do you plan to switch 1.0.4.2 to “stable” ?
regards
Hello phil31
You can consider 1.0.4.2 is stable.
is it an official update ?
thanks
A 1.0.4.2 is not official firmware, it is a beta version. but you can only use AT+WCHECK at 1.0.4.2.
Thanks
i’m using now 1.0.5.2
i set AT+WCHECK=10,5,3 (if i right understand, do automatically PING to the AP, each 10 seconds and reboot if failed answer)
i right receive the [OK], but i don’t see (wireshark) any PING request from my WIZFI device !
did i miss something please ?
Wiznet team,
as you stop the development of your W250, do you stop too the forum support !?
thanks
